I've got a pair of Tucker Sno Cats.
One's a '79, the other a 1980. The drive train is very reliable, relatively simple and parts availability is excellent.
The engines are Chrysler Industrial 318's and the transmissions are New Process 540's, which are 5-speed, non overdrive. Tucker uses a transfer case of their own design and the axles are Dana 60's. Pretty simple, huh?
The Dana axles are rear axle type in that they don't have steering knuckles. The axles are attached to leaf springs which attach to turntables. When you turn the steering wheel, you are actuating a hydraulic control valve which moves a hydraulic cylinder. That cylinder then moves both the front and rear turntables; in opposite directions.
So if you want to turn left, the whole front axle assembly (and both front tracks) turns left and the whole rear axle assembly (and both rear tracks) turns right. It's known as "crab steering".
The track system is what I'll call "modular". Whereas the Mattrack system uses something like a snowmobile track, My Tuckers have rubber belts that steel grouser bars bolt to. With a Mattrack, if you tear a track it'll get real expensive, real quick. But if I tear a belt, I can replace only that belt, or I can splice in a new section of belt. Similarly, I can replace one grouser bar, if I break it.
Tucker has been in business for over 50 years and is still owned by the same family. Once they reach a certain age, Sno Cats are a lot like aircraft, in that they don't go down in value as long as they're kept up.
I'll warn you though: It's an addicting hobby!
