thinking of doing a manual swap hydro/vs regular...
twoslo4five0
3/4 ton status
Living in a dump, VA
im thinking about do the manual swap...should i go hydro or manual linkage...the truck is not a dd but is a street trail rig...i think i want a 465 205 combo...not real clear of the advantages and the difficuly of instillation...i dont know if this applies to the same thing but eventually im gonna run hydro assist steering..fill me in..
I have never worked on a manual linkage 465 but I have seen plenty of the NP435's in fords......the linkage gets all out of wack when the rig is flexed and the clutch could not be dis-engaged at times. It made for some funny moments on the trails.
Plus the hydro is easier on your legs.
Go hydro. My '80 lost the linkage on the drive home from work the other day. I had to drive several blocks in stop and go w/o a clutch. Not fun. Hydro, you may have to replace a slave, master, or line someday, but no adjustments, no exploding linkage, no problems. The hydro is a bit more work to install on the firewall, but definately worth it. Hydro is definately on the top of my list of upgrades.
What everyone else said- go hydro. I used an adapter from advance adapters so I could use my mechanical bellhousing. I've loved my setup and it has never given me problems. Have fun!
It's the only way to go :wink1:
The mounting locations are factory marked on the firewall so it isn't
that bad of a job,I think the hardest part was replacing the pedal assy.
Yup. The pedals were a PITA.
Same thing happens with Chevys. Especially when the body mounts start to rot away and the cab flexes MUCH more than it's supposed to.
Been there, done that. Get hydro.
the hydro stuff can be pretty tough to find. i was looking forever and gave up and went mechanical. i really like the setup, only wheeled it once, but it never gave me any trouble getting bound up, etc.
http://www.novak-adapt.com/catalog/kit_hcr3.htm
:D
The only problem with this kit is that its for a 10.5" clutch iirc...since I am gonna use a 13" clutch, i guess I am SOL.
Seems, I'm in the minority here, I've had troubles with the Hydro in my '86 C10, rotted lines, bad master, 3 slave cylinders (C10 is my DD), but the manual linkage in my '73 has never bound up, never given me any troubles.
I'd say manual linkage all the way, unless your doing hard rocks all the time where the thing is twisted constantly. But even twisted up, my '73 never bound up where I couldn't release the clutch.
The hydro setup in my '97 is even worse, the slave cylinder is the throwout bearing (they call it a hydraulic slave cylinder), goes bad about half way through a clutch, wrecking the clutch disc by spewing fluid all over it. That truck is a pain in the arse to remove the tranny/transfercase too, and nothing like having to do it unexpectedly with half the clutch life left, which I've done twice already.
Anyhow, my vote is for good old reliable manual linkage.
hydro clutch vs manual, ford vs chebby... .all preference and use... i had hydro in my 86, my 79 has manual, less moving parts and i like it that way... its not that tough if you weigh over 100lbs...
