So what i did was, backed off all the rockers(all valves being completely dhut, all rockers loose) plugged off all vacuum lines, and plugged the throttle bores with some big rubber caps. Then i just took a cigarette and blew the smoke into the one vac line i didnt plug. The smoke only came from the throttle shafts. So i pulled the throttle body off and put it on the bench and checked again using a different port. Still lots and lots of smoke. Then i taped off the intake and blew smoke into it. Couldnt SEE anything. but curiously i could still blow air into it. Unlimitedly. It would build "pressure" but i could blow into it (slowly) non stop. Not nearly as fast as i could blow threw the throttle body.
THEN, I made a rubber plug deal and stuck it into each of the cylinders and blew threw it. They were all pretty consistant. Tonight after work i got a buddy coming over to listen to the exhaust and intake to see if he can hear anything while im blowing in the cylinders. i know the 1psi i can produce with my lungs aint much but its worth it for free quick preliminary checks.
