Holy cow that thing runs rich! Smokes more than my diesel does, LOL!
Two things, as you mentioned, 02 sensor is NOT working. It is either totally plugged up, or bad. 0V = lean, VERY lean. ECM is gonna lay the fuel into that engine as best it can to try and get an O2 reading from it.
Two, your fuel pressure regulator has to be bad. Your fuel pressure is way too high if it is making that kind of smoke. Even a fully enriched mixture from the ECM should never be able to generate that kind of smoke.
