PsRumors
I know this would probably be better suited for The Garage but I didn't wany everybody to respond. I was more interested in the response from people who show enough desire for these trucks that help support this forum.
So anyway, I am considering selling the '85 Burb I have been working on. Its' current state I will try to describe as best I can and see if you all can give me some pointers.
Engine is a your basic 454 less than 1k miles. It has been recently rebuilt and runs, pulls strong. The intake manifold is an Edelbrock and when I installed it apparently I did not seal it well and it drinks some anitfreeze, not bad but does. It also has a new Edelbrock 650 with electric choke.
Trans is a 4l80e from Bowtie Overdrive new less than 1000 miles. It is controlled by a Compushift controller and shifts well. Not much to say here, it works as you would hope it would.
Transfercase is a rebuilt NP205. The shifter linkage needs to be finished up to work with the stock shifter or a new shifter purchased.
Axles: Front is a D60 with new brakes, rotors, calipers, hubs and a new right u joint. It also has a new set of Warn Premium lockouts. Needs the pinion seal replaced. Rear is a 14bFF with disc conversion and a Mag-hytec cover. Needs to be shimmed to correct pinion angle. The front needs an alignment.
Suspension; Front Springs are from ORD and are Rough Country HDs, Rear Springs are Stock with 2 1/2" shackle flip. All bushings are poly and bolts are greasable from ORD and did the front Upper Shackle kit. Shocks are Rancho 9000s.
Also did the ORD bolt in Steering brace.
The body is pretty straight and very solid but needs paint. No rust. Interior is nice. A/C does not work. This is a K20 so is emmisions exempt in most states. It is a Silverado which is loaded including rear heat.
The tires are in need of replacing and probably the wheels. I have a set of new American Eagle MT knock offs.
If I was going to sell, should I sell or part it out?
If you took the time to read all of this and tell me what you think thank you very much.
Here is the build thread for some pictures: http://coloradok5.com/forums/showthread.php?t=209001
