Sorry to everyone on the minispool for full float. I looked and looked before getting the full spool.
However are you guys not concerned that you basically took a bullet proof rearend and made it a weaker with both axles locked into a minispool and having those 4 pins support all that torque?
With a full spool or full carrier locker you dont have that weak point. Welded you might but If you weld the spiders all together and then the spiders to the carrier like you are supposed to.... I guess if you welded that minispool to the carrier then it would be stronger. However that minispool looks absolutely no different than welding and is 180$ more than welding!
Dont seem worth it to me.
Glad I didnt know about it when I got the full spool. I might would have tried to save $60
