Thoughts on a Rough Country Lift
those r/c kits should ride better than there leaf spring lifts for our trucks.
if your truck is a crew cab 1500 is it a real 1500 6 lug ? make sure its not a 1500hd 8 lug truck . totally different parts.
that kit looks straight forward and simple.
just need an alignment when done with install.
also metric allen wrenches for the ball joints to keep from spinning .
the rear blocks will give it back the stock rake more than likely . compared to most lifts/level kits I have installed being tad high in rear like stock.
Mine is the 6 lug, not the 1500hd.
I was thinking that kit with maybe a 1" coil spacer would make it look just about right.
coil spacer harder to install as compressing spring more and = stiffer ride.
seen a guy do a 1.25 " and looked good but real hard to install with basic tools.
they do work and are effective .
Ive got a 2" Rough Country lift and some Bilstein 5150 shocks and its a great combo, esp for DD. off roading its a bit soft IMO, for anything major. I stuff the rear wheels pretty easily.
The Rough Country Shocks are junk IMO, the bilsteins hold up much better.
