Thoughts on alignment specs
it should have a negative toe in, usually about an 1/8". If this is your Blazer.
Wow it's good your caster is dam near identical on both sides, likely your axle is pretty straight.. I agree with the toe, or put it at 0 but that depends on how worn the steering stuff is.
Toe should between -.12" and -.25". At zero it'll wander and feel vague on center...
