I have a set of ORD F250 shock towers pretty much ready to go on my 87 K5.
Here is what I did and looking for rest of info from you guys.
Cut the rivets that held the front brake line brackets to frame so I could get just past the hump for stock shock mounting and needed a flat surface.
Now whats the best way to install them because I need to set the shock at around 5 1/4 of shaft showing. So what is best route to get the shock where I need it as in length wise and then to least get one hole drilled through bracket and frame.
Know I am over thinking this at the moment and will come to me if a few when I relax and think this through.
