Personally I would not change anything if it works.If you had this style of grille/lights on 89-91 Blazer, would you consider converting to the Silverado quad lights or keep it the way it is? I realize converting requires core support, buckets, lights, etc.
I agree - as a matter of fact I liked it so much that I bought Cody’s front core support and front grill assembly off of that Burb.
I prefer that look over the quad headlightsIf you had this style of grille/lights on 89-91 Blazer, would you consider converting to the Silverado quad lights or keep it the way it is? I realize converting requires core support, buckets, lights, etc.
I converted mine from the quad ‘91 setup to the singles for a ‘91. Sole reason was lack of options for brighter headlights. I could have taped four mag lights to the hood and had better light output than the stock quad setup.
Light output is quadruple over the stock setup. I’m not joking. I would never switch to a quad setup.
