Thoughts on this lift kit
91 Jimmy
Michigan
What do you guys think about this lift? http://www.offroaddesign.com/catalog/3inchliftsystem.htm
I called and talked ORD about it and for everything pictured he said it would run about $1,000. Would I be better going with this kit or buying just the stuff I need seperately. I like the DIY4X shackles better but will still need all the front suspension stuff, u bolts, brake lines, etc.... Are tough country the best bang for your buck for front lift springs?
ORD knows their sh!t, and that kid includes EVERYTHING.
I'd say you're probably saving money buying it all in one shot, IF it's what you want to do.
tough country is definatly the best over the counter springs for a good ride.i have 800 in my 6" with everything but rear springs. you can always sell the shackles and buy the diy's
I've had good luck with ORD's suspension components. I'm pretty much running what they now sell as kit, except for the shocks.
i have spent well over 3-4 grand in years with ord. i just ordered 1500 more for the next build. love there stuff.
and if you want diffrent stuff or delete stuff just ask and thay can swap it or deduct it from the price.
Do you know what kind of leafs they use in their packages? Also, is all the stuff in that kit really needed for just moderate off roading, mostly sand dunes?
that is a fully loaded option kit. and thay sell tuff country.
and if you want a little less skip the fancy shocks and sway bar disconect kit as just ditch the sway bar and skip the heavy duty shackles and reuse yours. last if you want easy install skip the full replacement rear poly spring bushings .
but for best info i would call and talk to stephen him self he has so much info its not funny. he will direct you in the correct direction.
Considering that kit is $400 of just shocks, yea its a good deal. Bang for the buck, thats a good price for all of that.
Pickup shocks from that edelbrok sale someoen posted elsehwere....
