Venanzi85
Registered Member
I am doing some research figured Id ask on here before i make this purchase what are your thoughts on Vintage Air? looking to purchase and install on my k5
Not to be some I internet dufus, but your experience surprises me. I had the stock R4 compressor in my '90, and have now switched to a Sanden, and have no problems staying cool, even though the truck is black. The in cab parts are factory, but I have the parallel flow condenser and Ford orifice tube because of running 134A. I even go wheeling with the windows down in Moab.I have a sure fit kit my k5. I've yet to use it in the summer but it seems that it cools damn good IMHO. I wasn't going to run ac at all but I was originally building the k5 for the wife. So that's why I opted for the ls swap and the vintage air kit. I have a pancake compressor in my c10 that's ls swap with a dirty dingo bracket with an upgraded condenser and it's not near as good as the vintage air.(yes I swapped out the blower motor)
Factory system doesn't have that, of course.You guys setting the temperature correctly on the probe that goes in the coil? When I installed mine and had someone fill it for me, the compressor clutch would cycle a lot. After adjusting the temp probe on the unit inside, the clutch would stay on longer and the coil would get cooler. They said turn it till it “ticks” and go another 1/4 turn. (I think 1/4 turn, it’s been a while)
But yes, I realize the units are already undersized for a blazer. They’re more for hot rods and small cabs.
