Just don't overboost it, good way to destroy your engine. Keep a close eye on your EGTs and keep your boost at reasonable levels.
In my experience a 6.2L is not as quick of an engine as a 350 is by any stretch. What they have going for them is fantastic mileage, and despite being slow all the time, the torque they produce makes sure that you don't go any slower when loaded.
If you are looking for a go fast engine, or are looking to improve acceleration, a 6.2L / 6.5L is not going to impress you regardless of how well geared it is. My 6.2L powered offroading truck has to be decelerated then downshifted to climb up hills all the time. Thats with 4.56 gears and 33.5" overall diameter tires. With the 2.73s and the same tires I was hardly able to maintain 65 mph, literally drove it in 4th gear (1:1) with the pedal on the floor the whole way, shifting it into O/D (I have a 5 speed manual trans) would result in a loss of speed. With the 4.56 gears I am able to cruise at 75 mph in 5th gear on flat ground, but definitely not in hilly areas.
The reason I said to use a turboed 6.5 with a Banks turbo is that the engine already has lower compression to take a turbo, that way it's hard to overboost it, just take advantage of the margin that was available and the stock turbo didn't use.
I agree the GM diesel isn't a screamer it's more of a torque engine, which is why I like it.
