Thread sealant for bolts that protrude into water passages
Justin V
I should've stayed up there
Missouri
What do you guys like to use?
It looks like wifey's new jeep engine has one head stud the goes through to a water jacket in the block, and it is bubbling slightly when the temp gets up to normal.
I've used Right Stuff, the white PTFE stuff that you brush on, but what do y'all like?
The only good thing about this is that I have to drain the water anyway, and the head stud is accessible without removing anything else....
If you plan on never taking the bolts out again,use Permatex Indian Head Gasket Shellac on the bolt threads..
That stuff dries to a semi solid paste that will stop any liquid--getting the bolts out later may be an issue though,heat will help soften it and make it come loose easier.
