Three day 3link (wishbone rear)
73 K20 long travel rear suspension links and coilovers
Good morning gents!
After a long few days we took the original truck we put our first kit on to the next level of BadA$$..
This is now owner by our great customer Alex! He absolutely was an animal busting his but alongside us for 3 days to get this rolling.
Our goal for this was to have a decent amount of travel out back but not have it intrude into the bed too much. This truck does a lot of different things so it’s not specific to any specific discipline.
We decided on a wishbone upper for the sake of maximum triangulation.
The lower links are very long near 70 inches! They have our single shock low ratio trailing arm brackets. This is 1.3:1 ratio and uses a 14 inch shock and that protudes 6 inches into the bed. This is also designed to keep 40s from shredding the stock fender which is why it bumps out below the fender line.
Bump stops will be striking the full width truss and the bumps are 4 inch travel.
We are working on building a plate shock tower for the rear which are similar to our front towers.
Here’s a few pics of the progress. I’ll post more as I can.
Thanks for all the hard work @secutright and @jkroberts this wouldn’t have been possible with you guys!!
EE579A52-60E8-4E9D-AE99-172C690A4697.jpeg 7390814E-E87C-44DA-823A-3FE33A1DAE8F.jpeg B80F43C9-A5A1-4DC5-8F39-20908C0E9699.jpeg 462D1741-E5B4-415B-B8BE-A50803F87920.jpeg FF08DDF5-16CC-4BEA-B4ED-16AF7CF70C10.jpeg
Finished burning in the mounts today and got started mocking up the towers! Moved them back off the flat part of the frame to where it kicks up so I need to notch them accordingly but the height is set. It's going to be nice and low profile!
