I just put an Edelbrok 1406 on my SBC. I have a TH350 trans. So I hook up the throttle cable, fine...hook up the Kickdown cable, fine...there is no place to put the throttle return springs. Edelbrock indicates it goes on the bottom where the kickdown cable goes, but there is really no place for it there, i tried hooking it over the kickdown cable but it interferes with the choke opening all the way (and probably will interfere with the kickdown cable at some point). Looks like I will have to run it from the front, on top opposite the throttle cable. Now I need to find a suitable bracket. Do I need to use one of the Tall SBC brackets that bolt to the front two drivers side bolts on the intake manifold? Thanks for any advice.
