BlackBourbon
i tried looking around but i need some help. here it is.....
motor is an '87 TBI350
this weekend i noticed the burb not running right and took a look under the hood. the drivers side injector was spraying halfass, then would drip a bunch and backfire, then stop, spray, etc.
i pulled the injector pod off and cleaned injectors real good. yadayada....
long story short, on the install i broke the throttlebody housing where one of the hardlines for fuel threads into it at the back.
my question to the injection gods here is....
1)should i find a whole used throttlebody for 350?
2)find just the 350 throttlebody housing and swap it?
3)is a 454 throttlebody a direct swap and good modification since it flows more cfm?
