Does anyone have a book or know of a web site that shows dimensions of tie rod ends and drag link ends?
I have a dropped drag link and the end at the pitman arm is bad.
It has an overall length of 4 3/4".
The length from the threaded end to the grease fitting is 3 3/4".
The thread where it screws into the drag link is 7/8-18 right hand thread.
The taper major (large) diameter is .791".
The taper minor (small) diameter is .772".
The length of the taper is .690".
The stud length from the ball to the end of the 5/8-18 thread is 2.125".
The 5/8-18 thread is .875" long.
From the end of the 5/8-18 thread to the large end of the taper is 1.562".
The pitman arm is stock 1986 K10.
I have searched the parts stores and the web and I can't find one.
If you click the pic you should be able to see the dimensions. I hope.
Thanks,
Mike
Thanks,
Mike
