brian052484
Registered Member
I was hoping that someone might be able to point me in the right direction, or give me some advice on what to do!
Im running a 10b front axle, with sky's crossover/hi-steer kit.
I got everything installed fine, but I ran into problems with clearance between the tie rod and the drag link. I am running 52" springs up front, so the axle is moved forward slightly, making the tie rod run directly under the drag link where it connects to the pitman arm. That doesn't allow for much flex
I called Sky, and they told me that it's common to move the steering box forward (and down) for this application. That doesn't seem like a reasonable alternative, as the steering box doesn't mount flush against the frame (flat, I mean... it has curves to match the box), and as I have already welded on my ORD frame reinforcement plates.
So, for the time being, I moved my tie rod back to the original location. But of course, ran into more problems: the tie rod rubs against the leaf springs, because it mounts on top of the knuckle's TRE hole, rather than the bottom where it was on the original knuckles. Can I just add a shim under the springs that's 1/4-1/2" thick, with a slight angle, to give me more clearance? That seems the easiest solution, for the time being.
Any ideas? Sorry for the ridiculously long post.
