The previous owner had some hard plastic "spacers" between the tie rod end and the steering knuckle, presumably to lessen the friction. However, by putting them in, it keeps the taper from fully inserting into the knuckle. Wondering what is more important, getting the taper all the way inserted, or giving a smooth surface to rotate on. With the spacer in, it looks like about 1/8 of an inch of he taper is not in the hole.
