tie rod ends
i was actually just doing some searching on for myself. from what i have read dana 60 dana 44 and 10 bolt all have the same size holes in the steering arm for the tre to go in. as far as the tre's go the stock tie rod is one short tie rod and a long tie rod makes up the rest of the length. are you going to use and aftermarket tie rod with the short endsand a threaded tube, or are you just replacing the stock components?
