magik235
Still Alive
I have searched the web and can only find tie rod flip bushings for a Dana 30 front axle. Does anyone know where I can find tie rod flip bushings for a GM Dana 44?
Tie rod flip bushings?![]()
Yes, these were the 1st Design years.'76 and older D44's have the tie rod up top, not over the leaf spring but on top of the arm on the factory knuckle. As mentioned, they use a special tie rod that has several bends in it.
You can use a straight tie rod with the tie rod over the factory knuckle setup (without high steer) depending on leaf spring configuration etc. Usually you have to install the tie rod before the leaf springs to make it work.
Perfect. Thank you for the link. This is exactly what I needed.To answer your question......
http://www.wfoconcepts.com/pr/Tapered-Bushing-GM-Tierod/3163/3204/4086
