The new parts may not be exactly the same as your originals so chances are the measurements wouldn't have helped much anyways..
You can simply measure the distance between the front rims,take one measurement from the rear of the rim about halfway up,and the same at the front ...it isn't so simple trying to do this alone with a tape measure however..you want the front measurement to be about 3/16" less than the rear one..
What I do to set toe in,is use something like two pieces of EMT conduit that will slide inside one another,I cut a slot in the larger one and use a hose clamp so I can slide the inner piece out and secure it --and position the front tires "straight ahead" and put the "measuring stick" at the points on the rims mentioned above and adjust the tie rod end until the rear measurement is 3/16" more than the front one..
If the steering wheel is off center after doing this,the drag link can be adjusted longer or shorter as needed to center it again..
