andyblack
Registered Loser
Does anyone have a half ton pickup with a 10 bolt front axle that has the tie rod on top of the steering knuckles? My '85 truck has the tie rod on the bottom of the knuckles, but I need to replace the driver's side knuckle because the studs on top where the steering arm attaches are broken. The only knuckles I can locate have the tie rod on the top. They're on an '85 CUCV Blazer. Will converting to the top tie rod style knuckle cause clearance issues? I don't see how it would matter, but if anyone has a pickup with the tie rod on top of the knuckles, please respond. I need to fix this thing quick.
Bummer. I had to take it off and start over.
