Tie Rod Question
T_Spurger
Registered Member
Texas
i need to know how long the lenght of DOM needs to be for the tie rod on a dana 60. i am using the 2026 and 2027 tre
Uh, not to be an ass, but... MEASURE. If you have the old tie rod, measure that one, do the necessary subtraction/addition. If you have no tie rod, set the tires 1/8"+ farther apart in the back, and measure c.l. of the holes.
Why not use the strongest TRE which is the ES2010L and ES2010R ? These use the same taper as the factory ends but have a 7/8" thread with a very short shank which is what makes this end the strongest.
