Tie rods ream tool
I got mine on Ebay... or for that matter, you might find someone localish to you with one.
You're a bit far from me, but worst case you can pop your pieces in the mail...
-- A
What are you tapering for 1ton tre's? The only people I've heard of doing this are jeepers since theirs are actually smaller.
You know 1/2, 3/4, and 1ton stuff is all the same size right?
Draglink ends have a bigger taper. Most crossover steering arms are tapered for tie rods. Draglink end can handle more of a angle. Plus, some pitman arms from the junkyard have smaller tapers. Some of us can't use the Ford drop pitman arm because it hits the spring while the suspension is compressed. I got my reamer from AFCO. Tie rods and draglink end take the same 1 1/2" per ft reamer--you just ream the hole bigger for drag link ends.
