joshthemule
My TC was leaking pretty bad so I tore it down to replace all the seals and inspect the gears and what not. Now I'm putting it back together and a couple of the seals seam really tight. I just did the front output shaft seal and re-installed the shaft and flange. It was a really tight fit to get the shaft through and now there is a lot of resistance to turn by hand. At least a lot more than when I tore it down. Is this normal? Will the seals loosen up once the fluid is flowing?
