I've had this ongoing clunking/settling thing going on. I replaced my ujoints last weekend and the truck was still exhibiting some weird behavior when braking.
Yesterday I rolled into work and heard a squeek-squeek-squeek when I was coasting in the parking garage, coming from my driver's rear wheel.
I was pissed thinking I had installed a bad u-joint or maybe I had a wheel bearing job to do, so I got home and had my roommate look under the truck while it was coasting. We determined all the racket was coming out the wheel, and when he checked the lugnuts, all were loose except ONE.
About 4 weeks ago I pulled some 2" blocks out the back and replaced with zero rates. I torqued the wheels down afterward, but it just goes to show to ALWAYS RECHECK after 100 or so miles. The passenger side was just as bad, but at least all the lugnuts were seated.
When I tightened them down it made a night/day difference in driveability. It even knocked my steering wheel out of line since I had adjusted it recently with the rear wheels loose
Anyway, safety first!
