handloader90
Building!
I know about the two nut trick and have used it successfully in the past. I personally like to put a washer between the two nuts and use anti-seize, seems to help when taking the nuts off.
I have also over-tightened studs this way, I ended up cracking the area around the hole the stud was being installed into on an aluminum intake manifold... kinda sucked.
I'm getting ready to install some ARP studs in a Dana 60 knuckle for crossover steering and did a little research. Installing the stud hand tight is what I've came up with. Install the stud hand tight, place whatever it is your installing over the studs and torque the nuts to spec.
This is also the procedure that ARP lists for their head studs so I'm assuming that it would not be an issue with other things.
