MrSchaeferPants
Oh, and if need be with the bathrooms. Lowes/HD/HF sells a tile hole saw. If you need to get around pipes. Cleaner look than cutting around it. Has a plastic base you affix double sided tape type stuff to (comes in the kit) position it on your hole, and drill it out. On the floor, have to put a bit of water in the base, the double sided tape stuff keeps the water in.
