Using this little write up:
http://coloradok5.com/forums/showthread.php?t=94834&highlight=Harv
I'm here:
Anyone have any bright ideas on getting these out besides buying the puller that I'd use once?
I've got small screws that fit, and I've tried pulling with vise grips and tried to get a crow bar in the mix as well, ended up popping a little piece off the cast frame inside the column, I think it'll be fine though, just not sure where I'm suppose to be prying from. I can snap some photos if necessary.
Any ideas are appreciated.
I'm here:
The next step requires a small puller. I used small screws and vise-grips on one and a small crow bar on the other one !! They are in there pretty tight too !!
There are two pins 180 degrees apart on the sides of the bowl. These are the tilt pivot pins and they need to be removed. Kent-Moore makes the special puller but I have seen other folks put a small screw in the hole and pull them out with Vise-grips. If the screws break you are hosed! The pins are harden and can't be drilled out if it gets screwed up.
