tilt, tach dash, more 1980
gn4u2c
Pa 17329 zip
SOLD SOLD
headliner setup and seats/ console in other add is all I have left
Are the front turn signal lenses intact? If so, how much?
They must be the rectangular headlight ones, since the round ones are different.
pm anwsered, I can get pics, yeah the lenses are fine if you take a pic of exactly what you want I will be 100% sure they are in great shape and you get exactly what you want. cool:wink1:
In this pic you can see the area that I have sectioned off. You can also the the damaged lens, it is missing a small chunk in the top center. I only need the lens for the passenger side, although if the price was right I would gladly take them both.
WAYNE had first dibs on it if he passes on it I will let you know pics will be posted of it this weekend. thanks
yes I have those exact light lenses they are both great. hows about $15.00 for both shipped to you ??? if you want them Pm me and we will exchange info.
I want it but I'm going to have to pass. I was buying it for a future 2wd project truck but I found out today I might be jobless in a month or two so buying parts that are going to sit just aint happening.:mad:
Will your colum fit into a 1986 K5 Blazer....is it in good shape? If so how much do you want for it + shipping to 04009....Maine
will the 1980 gauge cluster function in a 77? i dont have a factory tach which is why im asking. also how is the printed circuit board on the back?
Adam,
The steering column would fit, but the wipers will not be on the column. So you would have to re-wire your wipers.
correct just do yourself a favor and get a newer colum, these are pretty rare and the later one like you need is pretty common. you should be able to find one for 75.00 ish.
Ok dash is avalibble again to people in the order of posts, yes the circut board is great, it includes the lead wire for the tach, and the 4x4 light wire harness. it will work in a 77.
