Time for a lift what is everyone here running?
4 shackle flip with 4" superlift springs and 8" superlift springs on the front with 2 body lift to clear 39.5 Boggers......................
3" TC spring lift and 37" MTR's. I am planning to put 39.5" Irok's on with no additional lift.
after the first dent it won't matter any more. i'v got 6in. superlift all springs I like it. 35in. soon to be either 40in.mtr or 39.5 bogger already cut fenders.
The past 3 weeks I have been reaserching the same idea realy hard. what I have found out is Tuff Country or BDS will flex the best, And you can get Alcan custom springs for about 100 bucks more then the TC's, for all 4. I was told that the 4" shackl flip will flex better than all spring. "Less arch more flex."
AS far as changing the spring lenght your looking at a nice cunk of change. close to 2800 or so, with the steering mods. that dosent include drive shafts.
Good luck and I hope this helps
I have a 1-ton truck, and there are only two companies that make lifts specified for 1-tons...SkyJacker and SuperLift.
4" SkyJacker springs front
3" block and 2" add-a-leaf in the rear.
also have a 1" body lift from ORD.
I have rancho HD 4" springs up front + a 1" zero rate. In the rear I have stock springs + a 4" shackle flip, a 1" zero rate and revolver shackles.
in the short term I am tossing my stock length front springs and going with stock rear springs (52"). Do a search for this mod, its dirt cheap, it works, and its not hard to do either.
j
I'd defently order from ORD. 6" Tuff Country springs front + thier heavy duty extended shackles. (6.5" lift front.) and for the rear 4" Shackle flip + 3" Tuff Country springs. (7" lift rear.) Well, that's just my thoughts.
8 inch Shyjackers springs all around 3 inch body lift to clear 44 boggers /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
[ QUOTE ]
The shackle flip was gonna be a 4" shackle flip with new 2" springs from Tuff Country, then 6" springs up front.
[/ QUOTE ]
/forums/images/graemlins/thumb.gif Sounds good to me. I'll probably do the same.
