rx7gslse
ok.. as I supected in a 190k mile truck, time to replace a bunch of steering/suspension parts... Anyone have some tech write-ups or instructions to point me to (outside of the shop manual) to replace;
1) pitman & idler arm (these look like a pain in the azz to get off, no space!)
2) outer tie rod ends - these look a lot more straight forward.
3) lower ball joints. Uppers look recent, lowers look shot.
Toe is way off.. took it in to attempt to get it aligned and they wouldn't do it due to worn parts.. ran thru the checklist I found on FSC and my replacement list looks to match the shops recommendations...
This is on a 99 K2500 suburban 4x4 w/ a 66" RCD lift...
Also, cheapest place for parts??
at Autozone
pitman arm = $21
Idler bracket assembly = $39
tie rod end = $21
ball joint = $34
at Autozone
pitman arm = $21
tie rod end = $21
ball joint = $34
