andyblack
Registered Loser
Saturday morning I noticed a puddle under my gas tank. This is an '85 SWB pickup (carburated) with the driver's side saddle tank. 16 gallon tank. I removed the stock plastic "skid plate" to find an unbelievable amount of wet, nasty mud stuck in it. This no doubt contributed to the rust that I saw on the bottom of the tank. I could see where the gas was seeping out at, so I wiped the area with a paper towel to see if I could pinpoint exactly where the leak was. I must have wiped away the mud that was keeping the gas in because it really started leaking out then. I finally managed to get it to stop with some of that gas tank putty stuff. I could see another blob of the stuff that someone else had stuck on there some time in the past. I was going to sand the bottom of the tank down and paint it so it couldn't rust anymore, but it's so rusty that I was scared I would bust more holes in it if I even touched it.
So I need a new tank. What should I do - get a replacement tank from LMC? get an old tank from the junkyard? swap over to a Blazer or Suburban tank?
How much trouble would it be to do that? I know it's been done and I get tired of having to fill up the little 16 gallon tank every 160 miles or so. What do yall suggest I do? I had just filled up the day before it started leaking, but it won't take long to burn all that up.
