Timing and battery cable question
beastofablaze
CA
still workin on getting the blazer fired up.... is backfiring through the exhaust retarded or advanced? I was thinking retarded because of the way the valves open but i'm not sure.
Also my pausitive battery cable is brand new but the alternator wire is too short... anybody know where I could find a 4 gauge crimp?
what I use...
When I have to splice a thick wire like a battery cable,and any other wire up to 10 ga, I use copper tubing that has an inside diameter large enough to slide over the cable(s),and smash it flat with a hammer...then solder it with a propane torch,and rosin core solder..I make "lugs" the ame way,by drilling a hole in the flattened tubing,if I need one to bolt to a winch,for example..
Usually I use heat shrink tubing,or electrical tape to cover the "spliced" area,and cover it with rubber or vinyl hose or that crinkle wire loom stuff GM uses factory to keep it from chafing and shorting out...:crazy:
Thats a good idea right there... doubt copper would pull out especially after soldering it.
autozone on the cable..4 or 5 bucks and no effort lol
I was at autozone and kragen.... none of the alternator cables will reach my alternator. All those kids are stoners and have no clue what the hell you mean when you use fancy terms like "4 gauge" or "inline fuel pump". I'm about sick of wasting my time at autozone... seems like the same thing everytime I go in there. They have all the parts in the world for rice burners but not nearly enough parts for my chunk of steel.
