garydan
I've done this job in the past on my LS1 camaro, but I have a 400ci motor in my blazer and from the looks of it, its a different animal. I guess on these older motors there is a pulley and a harmonic balancer? From what I can tell by feel there is a center bolt, and 3 or 4 satellite bolts on the pulley. If I had to guess the satellite bolts are to be replaced by the pulley puller bolts. Once you get the pulley off, does the balancer just slide off (it seems to me that the balancer would only install in one way...since the timing marks on on there).
If someone could type out a quick procedure to get the pulley/balancer off I would greatly appreciate it.
