Mudstud
sbc 350. Hit it with the light last night and noticed the mark on the balancer was moving around while it was running. What causes this? The distributer is tight and cannot be turned.
There is a wire , I can't remember the color, but I am pretty sure someone will chime in on that, but to time it you need to unplug it, it's on the distributor, and it's the advance from the ecm.It's HEI. Based on what 1 ton said, this sounds like it's normal.
diesel4me said "If it computer controlled by an ECM,it could be the ECM or the wiring causing this.." is that all okay? "or the timing was not properly set," I don't doubt this at all. "you have to unplug a wire first in order to set the static timing properly.." I have no idea what you mean here, more specifics please.
It is a 1969 model 350 out of a Camaro SS. It has GM HEI. It also has an ancient Holley TBI system on it. The brain has dials to tune it in; idle, mid range, power and then choke and accelerator pump. When I did the test I did have the vacuum disconnected and I plugged the hose coming out of the TBI (on the tbi side).
So how should i set timing on this?
.I used steel gears when I replaced both and the chain..He doesn't have vacuum advance if it's factory tbi.I may be ignorant here, but wouldn't a vacuum advance and tbi/ecm advance work against each other? As in the vacuum advance moves and the ecm counters because it reads advance that it is not doing?
Never dealt with this, but seems odd.
