Timing gun
Discussion in 'The Tool Shed' started by beags86, Jun 30, 2019.
  1. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    Timing gun seems have taken a crap. Instead of just buying whatever pile of crap is behind the counter at the local China auto parts store I thought I would ask if anyone has a good one they have and like. I've never had one with a lcd readout or one with a built in tach or anything like that.
  2. Bent77
    Bent77 lil meanie Staff Member Moderator GMOTM Winner
    Dec 3, 2002
    25,210
    30,670
    colorado
    Build(s):
    Do you want one of those?
    I opted for the old style flash and go light. No dial, lights, bells or whistles
    Bowtie85 likes this.
  3. beags86
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    Idk. If they are worth it, I would buy one.
  4. YOUNGBLOOD13
    YOUNGBLOOD13 1/2 ton status Premium Member
    Jan 23, 2016
    151
    68
    Most if not all of those dial-back lights are inaccurate. Msd makes a good light
    beags86 likes this.
  5. HankScorpio
    HankScorpio Customize everything Premium Member
    Dec 9, 2016
    800
    1,046
    Laramie WY
    I like my old school Sun light with the dial. No idea if it is accurate but it seems to work fine. After having a fixed light I think the dial is nice to have. Its easier to see one mark without having to clean up the tab real good to read all the degrees. I really don't use it much any more, almost all my stuff is injected and adjusts itself now. It sits in the tool box with my dwell gauge taking up space. I also have never had a LCD or tach equipped one. My VW is the only thing I have with points where tach and dwell would be useful and I have those gauges separate anyway.
    beags86 likes this.
  6. beags86
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    Well my goal is to be all injection with timing control. But until i quit buying old shit that's probably not going to happen.
    HankScorpio and Smokinthehippies like this.
  7. Bent77
    Dec 3, 2002
    25,210
    30,670
    colorado
    Build(s):
    Do still need a light to test if the computer is right
  8. beags86
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    LS swap the world dude!:saweet:
  9. mrk5
    mrk5 The Sticker Guy Moderator GMOTM Winner Author
    Apr 20, 2004
    17,426
    7,563
    Northern Colorado
    Build(s):
    My only input is not to get the battery operated timing light. I thought it would be cool to not have the battery leads to mess with, but then I don't need one often enough so the batteries corroded. I just got one that connects to the battery. The only "new" thing I did was the adjustable angle.
  10. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,637
    649
    Wisconsin
    Build(s):
    I have an OTC stinger light I really like. It has digital timing so no knob errors and it also has a tach in the display, so far it works with HEI, CD (MSD style) and DIS (coil near plug)ignitions and I've tested the accuracy on the balancer with marks and it is dead on every time. The only thing it doesn't work for is it has a filter that won't allow it to trigger during cranking, so the engine has to be running. I would get the same one again because it allows you to test vacuum and mechanical advance curves and you don't need the timing marks or balancer tape on the balancer.
    Ok, I just looked and it doesn't appear that make that model any more, but it looks exactly like this one...
    Timing Light
    However, I'm not sure if that is the same or not so I can't say if it works for CD multispark ignitions.
    But in general, I would say it's worth it for a "digital" advance timing light, because the digital takes the error out of the knob type units with a sticker on them. Plus the built in tach allows you to do it all from the engine compartment so you don't have to climb in and out of the cab.
    beags86 likes this.
  11. beags86
    Jan 18, 2011
    10,153
    12,411
    Northern Illinois
    Build(s):
    3
    Thanks Heath, thats the one I had been eyeing. I think I'll add it to my next order to summit.
  12. Bowtie85
    Bowtie85 Some Beach, Somewhere Premium Member GMOTM Winner
    Dec 21, 2006
    4,144
    4,096
    Saskatoon, SK
    Build(s):
    I thought this guy got fired for saying that Eh @79rustyk10 :dunno:
    Fwiw I still kick it old school with a inductive light and timing tape.
    79rustyk10 likes this.
