bigchevytruckdriver2
Newbie
Putting the distributor back in my truck and have put it in wrong 3 times. Driving me nuts. The last time I had the wife bump it over with my finger in the number 1 hole until it started to pressurize. Then manually brought it around until the timing mark was on 0* btdc... or so I assumed. When I went to stab the distributor to line it up with the number one contact it definitely wasn't right vacuum advance tight against the firewall and the connection for the battery/ tach connections is pointing at the carb, seemingly about 90* out. Am I missing something, doing something wrong, please help. Not new to this either so that makes it more irritating. I know for sure the mechanical timing is correct as the truck was running before just not to well and the engine is basically new.
