Dedles1
Registered Member
This may be a noob question, but I dont care, I'm lost....What degree should I set my timing to? I have a 350 GM crate engine with about 12k on it that the P/O put in... straight stock engine
I thought I had the answer to this question when I checked the sticker under the hood. Then i realized that the sticker wasn't correct due to the original engine being a different side.. so wrong sticker
Now i need to know three things... what should i set my timing to? What should my idle speed be? and what gap should I put on my spark plugs?
