Timing/idle?
kablooie
LA, CA
I have a 1981 350 w/ 4bbl, AT & cali emissions.
For the life of me, I cannot find these specs anywhere... Searched here, called local auto parts store, thumbed through a Haynes manual, etc.
Anyone have an idea what the numbers are or any other places I can look??
There should be a sticker on the radiator support that tells....if it's not there I'm sure someone else will chime in.
forgot to mention that I looked at that too and it's for the original 305 (VIN Decodes a 305 from the factory). my assumption is that the specs on the label (forgot what they are at the moment) are specific to a 305 and not a 350.
For 81, they should be the same 305 or 350.
I need to go back and check but I believe 6 or 8 degrees advance at 700 RPM
