What you describe you were one probably two teeth off on the dist. The module wiring won't let you turn the dist. enough to bring the marks into sight.
module wiring wont let me turn the dist???
i think it was more like the vac advance hitting the carb that stopped me from turning it one way.. and vac adv hitting the cab the other way...
i sooooo need to remove my tcase drop... it has pitched my motor enough so the cap is bout on the firewall... my plugs in the back pretty much are...
