Timing on an 86 pickup
DUKSRULE
Va Beach Va
I have an 86 pickup with a 350 and need some help with the timing. What is the setting? Also do I need to take the vacuum hose off of the dist. when setting the timing?
Also I have an Edelbrock (sp) carb, which vacuum port does the distributor connect to on the front?
Also now that I found the timing pointer do I look through the tube? The pointer has a tube and several hash marks on it.
I'm not sure,but I think that "tube" is used with a special inductive factory timing device--you use the pointer and its markings to time it with a regular timing light.At least your motor has a pointer--my 86 305 had no evidence of one ever being there--it was a van motor,so you probably couldnt see the timing marks anyway in a van--ever look at a van,all you can see is a huge fan shroud.I had to set the timing by ear,and with a vacuum gauge. /forums/images/graemlins/crazy.gif
Oops--forgot about the vacuum hose question--I have a 1405 edelbrock on my 305--I hooked the vacuum advance to the ported vacuum port(on the passenger side)--but try it both ways,some engines run better with manifold vacuum to the advance(the drivers side port).Mine runs better with ported vacuum,at least it feels like it does to me--I think it has more pickup that way. /forums/images/graemlins/crazy.gif
