Re: timing question
Backfire through the carb could be attributed to the carb being too lean.
Here's my opinion. I've been doing alot of research on timing, and this is based on what I'm finding. Timing with a timing light really isn't the most accurate method. Try setting it with a vacuum gage, set initial timing at the highest vacuum. Then back it off 1" of vacuum to prevent detonation. Take it for a drive and check the new settings. If it is requiring such high initial advance, you need to be careful about what the total advance is.
I have a Demon carb which recommends 18-22* initial advance. The following is the best explanation I've found for why this is:
[ QUOTE ]
Due to cam over lap Performance engines make very little cylinder pressure at low RPM, therefore making the fuel very hard to ignite and to burn completely under these low pressure conditions. In order to accomplish a full burn of the fuel supplied, the engine will require enough initial timing to allow time for the combustion process to complete, or a get head start on the piston. This is why initial timing is critical and advance numbers that you've probably never considered are necessary when installing a Demon or for that matter any other performance carb.
[/ QUOTE ]
So what I'm saying is that if your engine likes the high inital timing, then leave it be. As long as your not getting any detonation, it should be okay.
