black dawg
How much timing do you guys run on your tbi 454s.
With the timing wire un hooked I have tried 4 6 and 8 degrees, and the power is much better at 8deg. The problem is that even set at 4 deg (and wire re connected) it runs like it has too much advance at idle. With the timing wire hooked up it adds about 20 degrees at idle.
