timing
gmaniat
Lawrenceburg, KY
I need help, 89 sub. new reman. motor what should timing be? Usually on shroud but I do not have original shroud. Ive been told anywhere from 10 BTDC to 0 TDC.
I believe factory has it at 0 degrees and the computer does the rest (computer sontrolled distributer). I hear you can bump it up to 2 degrees and get away with it.
