The tint will stick to the glass just fine, obviously some lines are raised a bit more than others, Lexus cars are bad for this too.
Use a quality film that has an aggressive adhesive, I liked to use a brand called Suntek. Really sticky glue. It will not sit down flat for the first couple of days until the tint dries out, but after it has taken hold, you can go back with a hard card and "fine tune" the lines and smash the tint down a bit closer.
Todays modern higher quality films will have no problem sticking to the glass with those defroster lines. I would use a metalized or even better would be a carbon film. Not just darkening the windows but also rejecting heat much better than a standard dyed film.
The windows on these trucks, especially the rear ones are not exactly an easy lick ans stick application though. Precise cutting and trimming are required for a nice, no light leak placement, and that's difficult to do when it's glass into rubber seals. Most all newer vehicles have a black out edge on the glass now, much easier to cut the film and place it without light leaks.
Also because it's glass into rubber seals, it's also extremely difficult to get a perfectly clean install, ANY water left in the sides will transfer any dust and dirt that was missed during cleaning, right back under the film during application. Too much dust will affect the adhesion and just look like crap.
If you have never done this before and want a clean install, I would highly recommend finding someone that has done it for quite awhile and has experience with these types of windows.
I've been tinting vehicle, home and business windows since about 2005, mostly automotive though. Some cars are somewhat easy, others are a real pain in the bootay.
