Someone may have put locktite on the balancer bolt...that can be a bummer..
I had one 305 engine I went to put a new timing chain in,someone stripped the fine thread 7/16 threads in the crank,and decided to tap it to 1/2"x13 thread and use green locktite to make sure it never backed off...
I had to heat the bolt up cherry red at least twice and let the heat soak into the crank,before my anemic flea market air impact would unscrew that bolt..
I only melted the timing cover seal,no big deal because it was being replaced anyhow,but if I had to heat that bolt up once more I bet the balancer would have been junk because the rubber bond got really warm...
I remember a guy buying a balancer puller coming back to the parts store,and he was holding the outer ring of it in one hand,the hub part with the keyway in the other hand..he asks "I can just hammer these 2 peices back together--right?...
Um..."NO!"..
...turned out the 3 bolt puller wasn't working for him,so he used a 3 jaw gear puller on the outer "ring" and succeded in pulling it off the rubber!..back then a harmanic balancer was a dealer or salvage yard only item,or a swap meet!...luckily I knew a machinist who had a pile of small block parts he accumulated and he had one he sold him for 20 bucks..
