I'm looking at ordering some BFG ALL Terrains off the web. My question concerns the aspect of the 35/12.50 Vs 315/70s.
How close in width and height are they?
cuervo said:I'm looking at ordering some BFG ALL Terrains off the web. My question concerns the aspect of the 35/12.50 Vs 315/70s.
cuervo said:That's my main issue the 35s are 15 inch tires but I'm looking at some 17 inch rims. Therefor the 315/70/17s are probably what I will end up getting. But just want to make sure they were close to a 35.
resurrected_jimmy said:8 on 6.5" only newer fords run 8 on 170mm
cuervo said:So I can assume the 8x165.1 is 8x6.5 then. I need to spend some more time reading the 14bff bible.
dremu said:And brushing up on your metric conversions
1" = 25.4mm, so yep, 6.5" = 165.1mm.
-- A
cuervo said:Na, I'm an American living in America that rejected the metric system, after about a 6 year test drive.![]()
Amen to that. Now remember that stock tires were L78-15 but you could get ZXCBY-12-Q on alternate Tuesdays =))AJMBLAZER said:Still haven't figured mine out - 11.00R16
They're 37" tall under a fullsize GM and about 11" wide in the middle of the sidewall.
I'll take the radial metric sizes over this one or the old A/B/G/P/Qxx thing. Q78-15...wtf?
At least the radial metric size is part of an equation that I can do in my head and roughly figure out.
AJMBLAZER said:No. Unmounted they're about 38" tall and under other's on here's K5's they're 37" tall with good tread. Mine so far seem to be about the same.
Then again this is tire stuff here so when 35's = 33.5" tall that might be perfectly correct.![]()
AJMBLAZER said:9" give or take a bit.
Just thinkin' out loud, hoping I could figger out that format of tre sizes =))
